Noise filter? Is there any type of noise filter I can put inline with my amps so that I dont hear the "whine" in my speakers? I have turned the gain almost all the way down on my Eclipse component amp but I still can hear the noise. It is driving me crazy! I have checked and double checked the grounding point and its clean. Any suggestions?:bang: |
check online or go to your local audio store they should have a noise filter you can add to your sound sytem |
Is it only when the car is on? Does is go up with rpm? What type of radio do you have? |
yes it is only when it is on. I have a 1 ferod capacitor (stinger digital) and I have a Kenwood flipout dvd yada yada player. Eclipse component amp pushing infinity kapa perfect components. |
alternator whine anyone? |
Originally Posted by xephona
(Post 10612603)
alternator whine anyone? *opps said he checked.....check the radio ground...* |
I will have to double check the radio ground but I believe it has to do with the capacitor. I hooked up the amp straight today without my sub to listen and it does not whine. SO that being said I may have to find another grounding point. I did not have enough wire to try another ground. It is alt whine but it is caused by the capacitor amplifying it I guess. Thanks for the respsonses. |
I rewired mine this weekend and had the same thing happen. I remembered that if you have your RCA jacks too close to the power or ground it will give you that whine. When you install a system run the power wires down one side and the signal wires down the other. Keep them as far away as possible. Hope this helps. |
© 2024 MH Sub I, LLC dba Internet Brands
