Remote amp turn on with factory monsoon Just wondering whats the best place to wire my remote amp turn on since I'm keeping the stock HU and don't really want to remove it, if at all possible. So I'm looking for the easiest power with key on??? Thanks For The Help Bryan |
bump NIGHT |
If you have a Firebird, I think you can use the power antenna wire, which is the pink wire in the harness behind the headunit. |
Can anyone help Its a Z28 by the way |
go to an ignition controlled wire, there is no remote |
why not just hook the remote wire into the fuse panel then run it under the carpet? |
use ignition behind the radio. yellow wire |
Thanks for all the help I will tie in behind the radio. |
© 2024 MH Sub I, LLC dba Internet Brands
