LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Wiring, Stereo & Electronics (https://ls1tech.com/forums/wiring-stereo-electronics-19/)
-   -   driver Side window doesn't work (https://ls1tech.com/forums/wiring-stereo-electronics/113431-driver-side-window-doesnt-work.html)
SSTYCOON Nov 10, 2003 08:31 PM
my driver side window will not go down. When you press the button, you hear a noise from under the dash, that my be normal though. The passenger side window works. What could be the problem?
thanks.
OctaneZ28 Nov 10, 2003 10:27 PM
Sounds like the ever-popular oh-so-infamous burnt out window motor.
Join the club!
VIP1 Nov 10, 2003 11:27 PM
Or it could be frozen (New England weather). Mine was this morning. It went down a 1/4in and that was it. I had to get out to use the toll booth this morning. As the day went on, it warmed up and started working. I think I need to lube up the mechanism. Maybe you are experienceing the same thing. Otherwise, like OctaneZ28 said, the motor is burnt.
--VIP1
SSTYCOON Nov 11, 2003 07:29 PM
thanks, i'll look into it, and it better be the cold weather and not the motor! :bomb:
MrHughes919 Nov 16, 2003 08:59 PM
mines doing the same thing and that noise is coming from under the dash...you say it may be a burnt motor? mines only doing it intermittenly like every now and then...
SSTYCOON Nov 18, 2003 07:40 PM
I still haven't bought a new window motor yet, I called PAceparts and they said it could be the driverside window module, thing i ask them if this device was bad would the passengers window work?, one guy at pace said yes, then another said no. So i still don't know whats going on, I hate to buy parts i don't need, well unless it Nitrious!
slow Nov 19, 2003 11:15 AM
the passenger side will work, if the drivers side window module goes bad...
Ryan.
LS1Baron Nov 21, 2003 08:40 AM
While you're at it, go ahead and replace both motors. It's easy to do. Buy your new window motor from AutoZone. They come with a lifetime replacement policy.
VIP1 Nov 21, 2003 01:28 PM
Are those Autozone window motors faster and more powerful than stock?
My windows are the slowest that I have ever used. A 2003 Hyundai Sonata LX that I rented (nice car actually) had better power windows.
--VIP1
LS1Baron Nov 22, 2003 04:43 PM
Yes, they are. They are actually Siemens motors, and work very well.
Bear Dec 1, 2003 10:03 PM
Arent there 2 AZ motors? I read once where there were 2 motors, 1 fits and 1 doesnt. If u have a part # that would be cool. Thanks Bear
770Guy Dec 10, 2003 10:27 AM
How the hell do you change the motor? I got my door panel off, and i cant even SEE my window motor haha.
Bear Jan 14, 2004 11:43 PM
TTT. 50 or 70. Which one is better?
VIP1 Jan 23, 2004 05:59 PM
Check this out:
http://shbox.com/1/4th_gen_tech1.html
There is an article about power windows in the "How To" section.
Here is another good link:
https://ls1tech.com/forums/showthrea...t=window+motor
-VIP1
© 2026 MH Sub I, LLC dba Internet Brands
