Sub box dimensions?
Old Nov 13, 2003 | 04:43 PM
No Juice's Avatar
Default Sub box dimensions?
Anyone have the dimensions for the 10" Sub box that fits in side on the drivers side?
I'm planning on making my own plexiglass box
Thanks
Old Nov 14, 2003 | 12:01 AM
samuraixv's Avatar
what you can do is use aluminum foil put it in side and mold it to the walls of the car and sprey with a starch or somthing like that to hold the curves then you can use that as a mold for your box then all you will need to design is the face
Old Nov 18, 2003 | 05:18 PM
No Juice's Avatar
Ttt.....
Old Nov 19, 2003 | 12:28 PM
Silver98camss's Avatar
The dimensions are not a fixed number. You must make sure that your subwoofer will have the proper amount of air space & that the depth of the sub your using will fit. I also believe subthump.com has their enclosure dimensions listed on their site. But as I said every enclosure is different depending on the sub your using's specifications.
good luck
