map lights bad? I just got my car tinted the other week. When i got it back, i pulled the fuse for the power windows so i wouldnt accidentally hit them. I noticed that the map lights stopped working so i thought it was due to the fuse. They're new led lights and ive only had them in for a month or so. Always worked fine no probs. So after i put that fuse back in, they still dont work. any ideas? |
your dimmer isn't turned off is it? |
it shouldnt be. how would it be turned off? if so, how would i turn it back on? |
Originally Posted by LWCS561
(Post 13458242)
Originally Posted by VIP1
(Post 13458535)
Its the vertical rotating knob next to the headlight switch. Don't do what I did in my old car and think I had a major electrical failure when it was just the dimmer turned all the way down :jest: |
i would have noticed if that was off..my gauges would be dim, and wouldnt my rear cargo light be out too? thats working fine. any other possibilities? |
Assuming that the tint shop also installed a tint strip across the top of the windshield, did you check that they didn't unplug the mirror connection? |
ahh...i didnt think of that. ill check tonight after work. where would it connect? |
the back of your rear view mirror, small clip |
thanks man, ill let you know |
© 2024 MH Sub I, LLC dba Internet Brands
