What is this?!?!
Old Dec 8, 2012 | 01:45 AM
KissMyTushZ28's Avatar
Default What is this?!?!
Hey guys. Was driving down the road and saw this switch in my 99 T/A 6 speed. It's right under the dash installed in the console right next to where the drivers right leg would be. It looks factory and connects to a harness but I don't know what it does! It's a 3-way switch(up, middle, and down) and I found it in the down position.
I stopped and flipped the switch to all 3 selections but I didn't notice and changes in anything. No lights on the outside or inside or anything that I could tell.
Here are a couple pics.
Here's the switch.
It is connected to the harness on the right with the gray conduit.
Also what is the plug on the right which is disconnected for?
Thanks guys!
Old Dec 8, 2012 | 02:20 AM
CamaroZ28_LS1's Avatar
weird I have no idea.
Old Dec 8, 2012 | 02:30 AM
Black_Z28's Avatar
TCS maybe???
Old Dec 8, 2012 | 02:43 AM
Idk. On my way home from work ill switch it up and try a burnout. I thought it was something the PO put in but with the way it is connected to the plug harness it looks factory. Idk what that other plug is for either.
Old Dec 8, 2012 | 07:15 AM
samckitt's Avatar
Just some thoughts. Turns off the skip shift, turns on cooling fans. Or maybe like a motorcycle my cousin had years ago, turns off the rear lights so the cops can't see you.
Old Dec 8, 2012 | 07:29 AM
WhiteBird00's Avatar
Ungrounded Moderator
It is definitely not factory but it's nice to know that the previous owner did good work when wiring modifications. There's not a whole lot of things that would use a 3-position switch so I would suspect it's a fan control but there are other possibilities.
The factory TCS switch goes on the panel next to the cigarette lighter.
Old Dec 8, 2012 | 07:33 AM
MMWS6's Avatar
Wider angle shot of where it connects? May be able to check wiring diagrams I have and figure it out
Old Dec 8, 2012 | 08:04 AM
Not TCS, Not Fans, Not skip shift, and so far not lights. I spun easily with it in each position, Skip Shift light came on AND locked out second in each position, My fans work great and are factory, and I hit the switch with the lights on and off and saw no change but I can't see it when I hit the brakes if it kills that signal. It puzzles me that it is a 3 way. Why 3 way? Lol
Old Dec 10, 2012 | 09:51 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Only two ways to find out what it is, talk to who installed it, or trace the wires and figure out what they connect to. Grab a voltmeter and see if there is any power going to the switch at all. I might just be disconected at this point.
Old Dec 10, 2012 | 10:31 AM
Jassick's Avatar
can't comment on the 3-way, but if i had to guess i'd say a fog light override? don't the fog lights turn off when the brights are on? about the only thing left that hasn't been mentioned specifically, but probably already checked if you did a thorough lighting sweep.
Old Dec 10, 2012 | 10:56 AM
NEW PICS!!
Ok, traced the wires. There are 3 inside the gray cover. Red, white, and black. The black is the ground which you will see in the pics, the red and white splice into a plug in the engine bay. Check it out and let me know what you guys think it is! What is that plug specifically?!
And yes Jassick, no lights of any kind that I have been able to figure out so far.
Old Dec 10, 2012 | 11:03 AM
creiss21's Avatar
I have a switch, actually it's a button located in the same spot and I was told it was some sort of reset button for my wide band? Idk if this is the same as yours since it is a 3 way switch and not a button like mine, but I just figure i'd throw it out there.
Old Dec 10, 2012 | 12:52 PM
Yeah my co-worker keep asking me questions of what it might be but they are all for something like a momentary switch or 2 selection rocker switch and I have got nothing so far.
What is that connector that it goes to in my engine bay? What does that connector go to?
Old Dec 12, 2012 | 11:24 PM
Jassick's Avatar
well there went the easy answers. is that the bundle of wires that runs over the passenger side wheel well? hate to keep going back to it, but i thought all those connectors were for the front lights.
hey, does your horn work? I'm just reaching at this point, trying to think of all the electronics infront of the radiator. plus i'm really curious as to what it's for.
Old Dec 13, 2012 | 12:31 AM
Yeah passenger wheel well. Yes horn works. IDK what this thing does but Ive changed its setting with the lights on and off and haven't seen a difference.
Old Dec 13, 2012 | 12:43 AM
TyCZ28's Avatar
see if its any sort of headlight mod...
with low beams on the foglights should be able to turn on. and with high beams on the lows and fogs should be off.. see if this allows a combo of foglights and lowbeams to be on when the highs are on... usually its a one time only thing but to make the fogs turn on too would make sense.
Old Dec 13, 2012 | 01:16 AM
onspeed's Avatar
Was the car ever sprayed?
Old Dec 13, 2012 | 02:14 AM
As I have said it does not change the lights! I know the stock light format for these cars, I did the fog/high, DRL, and high/low mods on my Camaro when I had it. Again, as I said it does not change the lights.
Old Dec 13, 2012 | 02:16 AM
Not to my knowledge or the previous owners and there is no evidence of any kind of a N2O setup. No connectors, cut holes, wire hook ups or anything.
Old Dec 13, 2012 | 02:51 AM
TyCZ28's Avatar
SOLVED!!! it is or was at one point a fan switch. its the SLP manual fan mod... wether or not it works dosnt matter thats what it is
http://www.xious.com/camaro/install-fanswitch.html
BOOYAH! it is the SLP kit.. thats why the wiring is soo clean
