LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Wiring, Stereo & Electronics (https://ls1tech.com/forums/wiring-stereo-electronics-19/)
-   -   interior lights don't turn off (https://ls1tech.com/forums/wiring-stereo-electronics/1707909-interior-lights-dont-turn-off.html)
jattgunman Feb 18, 2014 12:25 PM
I just replaced the battery on my car and now the interior lights do not turn off. The BCM is also clicking about every 10 seconds. It's not the door sensor. I unplugged the dimmer switch and it seemed to fix the problem until I started the car and then the lights wouldn't turn off... Could this be caused by a bad bcm?
tylerdietzenbach Feb 24, 2014 05:31 PM
It could be as simple as your trunk latch.. this happened to me once. It could be that the bcm needs replacing. The problems could be separate but unlikely. Did it all start immediately after the battery swap?
Michael Levitz Jul 7, 2014 07:27 PM
Interior lights staying on
I bought a 2000 Trans am. I am having a similar issue. The map lights will not shut off until about 10 minutes after i turn the car off and pull the key from the ignition. I assume that means my BCM is working fine? The car is in the shop for Trans. work. So I am just looking ahead of getting info on how to fix this next issue with my map lights. the dom light in the back doesnt work I think its just because the bulb needs to be replaced. Who knows. If its a door sensor or trunk sensor is it pretty easy to fix/replace?
zoomer02 Sep 17, 2014 01:19 PM
Did you ever find a solution?
jattgunman Sep 17, 2014 01:33 PM
Turned out to be really stupid issue and I just luckily figured it out. the interior light right above the rear seats was grounding out, the little tabs the bulb mounts to were touching the metal body of the car.
© 2026 MH Sub I, LLC dba Internet Brands
