1:00 displayed and only 98.1 will tune Hey yall, just like the title says, my 01 Camaro monsoon radio worked just fine from the day I bought the car in Oct '01 until after sitting in storage for a year while I was in the 'stan. The in dash CD player works just fine, all speakers work and sounds fine. the factory 12 disk changer in the back is jacked up but I think its just old. Ever time the car is off for a while the radio will read 1:00, i can program it and sometimes it stays the correct time and sometimes it goes back to one. Every time I turn the radio on it is tuned to 98.1 and if you try and change the station nothing comes in, just static. :bang: Any advise or solutions would be greatly appreciated. On a side note, it seems that when I go over some hard bumps when Im driving the SES light flashes on but it corresponds to the bump. Doesn't do it all the time but sometimes. Also, when I tried to get the emmisions inspection I get "Not Ready" and I have driven the car about 400 miles since being back. I heard that the PCM might have a "battery" that might just be old. Don't know about that. :confused: 01 Camaro factory monsoon |
No one has had anything like this?! |
This is weird. The car battery powers this stuff while you aren't using the car. I wonder if there is a loose wire that is causing you the problems on bumps and is what is causing the radio to reset. I just don't recall my radio acting like this with the power disconnected... |
© 2024 MH Sub I, LLC dba Internet Brands
