battery relocation
or if I didnt have 3" tall valve covers they could have stayed in the factory location.....
my ultimate plan is once i get everything where its going is to make some covers for that area so when you open the engine bay all you see is motor and intake the rest is just continuous fender well up to the rad support. Thats for another day though
the ls swap is pretty easy, it was all the wiring that was a pain for me. Nothing wanted to communicate like it should have (was a v6 car) had lots of vats issues since i converted to a manual as well.
I got all the coil pack signal wires soldered last night, need to pick up some wire look so I can tuck them down by the frame rail and then make the plug wires.
Im trying to decide how to go about the grounding in the bay with the negative terminal as it seems that the jumper off the actual terminal already is attached to the chassis is there really a need to double ground one wire?
Got all my photos and I'll doing the write up tonight. I gotta say though now that its pretty much done.... IT WAS SUPER EASY
