Power window issues
Old Apr 28, 2015 | 08:01 PM
dabest09's Avatar
Default Power window issues
Today I went for a drive and before I took off I rolled down my windows. The passenger window went about halfway down, then I tried to roll it up and it wouldn't budge. It works fine going down but it's almost as if the button doesn't want to work for it to go back up.
Did some trouble shooting.. Pulled the motor, tested it. It will only turn in one direction and that is down. It also will not work up or down if I try to use the drivers side buttons. So I tried hooking up another motor to it and it will only turn in one direction as well. I figured it was the switch so I purchased a new one and that didn't solve the problem either.
So I'm wondering if I have some sort of wiring issue now. Has anyone had a similar problem to this? Luckily I got the window back up for now but I would like to find a solution for this.
Old Apr 29, 2015 | 06:41 AM
WhiteBird00's Avatar
Ungrounded Moderator
Have you considered that it is probably the motor? You said you tested it and it would only go one way so that should make the diagnosis pretty simple.
Old Apr 29, 2015 | 09:08 AM
wssix99's Avatar
Save the manuals!
You can test this pretty easily. The switches provide power to the motor and just reverse the polarity to make the window go up/down. If you test the voltage at the motor connector, that should confirm pretty quickly if you have a switch problem.
BTW - the driver's side switch is wired through the passenger side switch.
Old Apr 29, 2015 | 09:43 AM
Correction... the passenger's side switch is wired through the driver's side (i.e. all window wiring goes to the driver's door first).
Old Apr 30, 2015 | 12:52 PM
wssix99's Avatar
Save the manuals!
Thank you. I have no idea how my brain was working when I wrote that...
Old May 3, 2015 | 06:28 PM
dabest09's Avatar
I plugged a brand new motor into the connector and it still would only operate in one direction. So that is why I'm so confused.
Could it possibly be a bad relay or do these cars even have those for the power windows?
I will try checking to see how much power I am getting from the connector that plugs into the motor and see if my issue comes from there.
Old May 4, 2015 | 07:11 AM
wssix99's Avatar
Save the manuals!
You probably have a bad switch. These switches are more complex than you'd expect. If you check out a schematic (see shbox) and test the circuits, you should be able to confirm where the problem is.
Old May 8, 2015 | 03:35 AM
dabest09's Avatar
I already bought a brand new switch from the auto parts store for the driver's side and it didn't do anything. Do you think if the switch is bad on the passenger's side it will stop the driver's side from working?
I will look into shbox.
Old May 8, 2015 | 06:34 AM
G8One2's Avatar
Its the driver door module / switch. Make sure the connector is fully seated on the drivers side. Or check the wiring.... Some cars have a module separate from the switch also, might need to look into that.
Old May 8, 2015 | 08:35 AM
dabest09's Avatar
Are you saying its the actual switch that you touch to make the window go up or down, or the switch connector with the little holes in it? I replaced the switch button as stated earlier.
Old May 8, 2015 | 11:10 AM
wssix99's Avatar
Save the manuals!
The problem is in the switch module. (Likely not the connector.) You need to test the circuits to figure out if the problem is with the switch on the driver's side or the switch on the passenger side.
If you have a spare switch in-hand, you can move it over to the passenger side and see if that's it. If that doesn't work, you'll need to test the circuits to isolate the problem.
Old Jun 27, 2015 | 05:25 PM
dabest09's Avatar
Bumping this back up. Is there any how-to's on testing the circuits? I suck at electrical stuff but my dad is pretty good. I'm not sure which terminals to check with the voltmeter.
I've moved the connector to both the driver side and passenger and now the window won't move on either one. Very frustrated at this point.
Could it possibly be something in the body control module?
Old Jun 27, 2015 | 05:30 PM
Fat Jesus 808's Avatar
I had the same issues with the drivers side, a new motor fixed it completely
Old Jun 27, 2015 | 05:53 PM
dabest09's Avatar
The motor works fine, I already tested it, along with a brand new motor.
Old Jun 28, 2015 | 08:09 AM
wssix99's Avatar
Save the manuals!
You need an education on the topic - a how-to won't be enough. You could read some books and pick up the skill or I'm sure someone has a series of youtube videos on how to use a multi-meter. That might be a good place to start. Learning how to read the electrical schematics is a little more challenging.
Old Jun 29, 2015 | 12:23 AM
dabest09's Avatar
Well I messed with it some more today and I think there must've been some sort of short in the passenger's side switch somewhere because if I moved it a certain way when operating the window motor it would intermittently short out and stop. I got some sandpaper and ran it over the copper terminals on the switch to freshen it up and it seems to work great now both up and down. I did notice a little water on the passenger's side carpet so I'm guessing some water got in there and might've done something and maybe dried out and now it works?
I hope it stays working from here on out, *knocks on wood.
