Monsoon or ?
Old Jun 29, 2016 | 03:56 PM
trailshredder's Avatar
Default Monsoon or ?
I have had my car for over a year now and thought the monsoon system was crap and found out this past weekend why. I installed new shocks and had to remove the rear seat side panels and much to my surprise, there are no speakers at all behind the panel! Looking for opinions on speakers to put in there. Should I find some OE monsoon GM speakers or are there better aftermarket ones available? I also considered putting 6-3/4” subwoofers in. Thoughts?
Old Jun 29, 2016 | 06:30 PM
JOHNNY59's Avatar
check out Keeaudio.
http://www.keeaudio.com/fbodyspeakers.html
Old Jun 30, 2016 | 08:07 AM
WhiteBird00's Avatar
Ungrounded Moderator
Are you sure the Monsoon system is still there? If the sail panel subs are missing, it's entirely possible that the system was modified by a previous owner and the Monsoon amp has been eliminated. If that is the case then all of the signal filtering for different speaker locations will be gone as well and installing subs in the sail panels might not work well.
Old Jul 9, 2016 | 03:00 PM
Appears everything is still there. ordered the cdt subs. Next question , the plug that is where the subs go has 4 wires, which two wires do use for the subs?
Old Jul 9, 2016 | 06:06 PM
VIP1's Avatar
Copy & Paste Moderator
So you see the amp by the spare tire?
Old Jul 9, 2016 | 06:07 PM
Yes, the amp is behind the spare tire.
Old Jul 9, 2016 | 09:20 PM
If the subs you bought are not 4-ohm dual voice coil (4 terminals) then you bought the wrong ones. If you got 2-ohm single voice coil (2 terminals) then you really bought the wrong ones and should not plug them in unless you want to risk frying the amp.
