Gauge wiring
1. Air fuel ratio gauge
2. Tachometer and shift light
3. Voltage gauge
4. Coolant temp
So what I wanted to ask is can I mainly use the wiring going to my gauge cluster and just splice in.
Ie. For example
Air fuel ratio gauge I know has to have a connection to the O2 sensor so that's out of the question but does it really have to be grounded to the engine block and if so why?
Tachometer- can I just splice into the white wire for the tach in the cluster for my signal wire?
Voltage gauge-just any hot and ground or do I really need to use the voltage input going to the gauges?
Coolant temp- can I splice into the coolant temp signal wire going to the gauge?
If so that will be a big help for most of the install. Hope everyone has a great labor day weekend
