Wire up lites?
Old Sep 24, 2018 | 06:38 PM
Chevymanty's Avatar
Default Wire up lites?
best way to wire up tail lites to dimmer switch
Old Sep 25, 2018 | 11:48 PM
VIP1's Avatar
Copy & Paste Moderator
What do you mean wire up tail lights to dimmer switch? Something not working right or are you trying to change something?
Old Sep 26, 2018 | 02:02 PM
Chevymanty's Avatar
New installation, got everything working great , press down on dimmer for highs works, when I press again all lites go out!
Old Sep 26, 2018 | 03:15 PM
WhiteBird00's Avatar
Ungrounded Moderator
Are you blowing the TAIL LPS fuse? What vehicle? It sounds like you're using one of those ancient floor dimmer switches (press on, press off). The dimmer switch should be in the headlight circuit and not connected to the running/tail lights. The two circuits have nothing in common except the headlight switch which provides two separate outputs for running/tail lights and headlights.
Old Sep 26, 2018 | 03:26 PM
MY_2K_Z's Avatar
Lights not lites
Old Sep 26, 2018 | 05:47 PM
Chevymanty's Avatar
Default Lites/dimmer
Got it right, alls well, next is wireing up blinkers and brake lite switch, shouldn’t be a problem but if so I will be asking for advice again on this thread, thx Dana
