Connectors C230 and C220
Old Apr 9, 2021 | 09:43 AM
Bosshog's Avatar
Default Connectors C230 and C220
I have a 2002 z28 with a th400 and 6.0 swap. Still running the ls1 f body harness in my car stock. The harness ended up getting cut and it happens to be the wire that run through the passenger side firewall through that rubber grommet. From my understanding these are for C230 and C220 which control the gauge cluster? My car is turbod and has been tuned and all that so VATS is tuned out. I’m just wondering what will happen if I try and start the car with those wires cut. Do they control anything important ? I read threads on them but just says stuff like they control some of the gauges. I’m just wondering if running the car with having those wires cut will mess anything up. And if I lose any of my gauges what will they be? I have a lot of aftermarket ones hooked up so it may not matter. Thanks
Old Apr 9, 2021 | 09:49 AM
fucter's Avatar
Yeah, they control the fuel pump
Old Apr 9, 2021 | 10:11 AM
Bosshog's Avatar
looks like I’m gonna have to splice them all back together lol hopefully there’s room
Old Apr 9, 2021 | 10:09 PM
JoshHefnerX's Avatar
Believe the obd data lead may be in that group also
Old Apr 9, 2021 | 10:10 PM
Bosshog's Avatar
yup I think I saw that earlier. I’m gonna be splicing them all back together tomorrow so we’re good regardless.
Old Nov 19, 2021 | 12:50 AM
jesusace1's Avatar
do you know if the two green wires and the two gray wires matter if the are mixed up a rat got into my engine and cut my c20 n c30 connector i matched all other cables but this 4 cables im afraid that i will fry something if i just guess
Old Nov 19, 2021 | 01:16 AM
Bosshog's Avatar
yes they matter. The green ones especially which originally was my problem I found out. They were backwards and I didn’t even know it. I’m not sure on the grey wires but the green ones do. I’m on a Holley terminator ecu now but yes.
Old Nov 19, 2021 | 10:16 AM
jesusace1's Avatar
so if i connect them wrong will it fry anything? im thinking of putting male/female connectors on those that way i can switch them if i connect wrong ones?
Old Nov 19, 2021 | 10:17 AM
Bosshog's Avatar
no it shouldn’t ruin any wires but whatever they connect to won’t work if they aren’t hooked up correctly. So you’ll find out real quick.
Old Nov 19, 2021 | 10:21 AM
jesusace1's Avatar
ok cool let me try and ill you know how it works also my map sensor got cut do you know the pin color order for it
i have a 2001 firebird ls1 auto
Old Nov 19, 2021 | 10:34 AM
Bosshog's Avatar
Map sensor wiring
Old Nov 19, 2021 | 10:52 AM
jesusace1's Avatar
thank you
