Headlight issue
Old Feb 21, 2024 | 05:23 PM
Celler4's Avatar
Default Headlight issue
Ok I have a 99 ta and my drivers side low beam headlight stopped working, just the bulb not the motor. Both sides still pop up fine and the passenger side low beam and high beam fine, I have changed bulbs/checked wiring and confirmed I'm getting power to the headlight socket. I am by no means an expert in wiring and looking at the headlight wiring diagram I cannot figure out what to look at/for. The only strange thing it was doing before it stopped working was the drivers side would be delayed when it came on but the pass side would already be on by the time the lights were up. TIA!
Old Feb 25, 2024 | 10:55 PM
VIP1's Avatar
Copy & Paste Moderator
If the socket has power but the bulb doesn't light, either its a bad bulb or bad connection. Swap bulbs to test. As for reacting slower, that could be a failing bulb, or a bad connection. Either at the bulb or further down the line might be a ground issue. Swap bulbs to test first.
Old Mar 2, 2024 | 01:29 AM
sjsingle1's Avatar
the main headlight connector ....the humongous connector hanging beneath the headlights....is very prone to corrosion .....ask me how i know....pop the connector apart and check it out
