im so pissed
Old Dec 25, 2004 | 05:23 PM
crazymofo1986's Avatar
Default im so pissed
i got the Alpine SPS-1005 Tweeters and Alpine SPS-170A 6 1/2's. put them in on the driver side so far. they are not half as loud. n dont even sound better then stock. is it goin to be diff after i do the other door. i dont even want to do the other one now. the tweeters arnt louder cleaner or higher or anything. only question i got is when i installed the tweeters i left that bulk thing i think is a mini crossover that connectes to the stock tweeter. should i have felt that in there?
did i do anything wrong? dont think i really could have.
happy hoildays
Old Dec 25, 2004 | 07:58 PM
Manoso's Avatar
yes you need that "bulk thing" it is a crossover and will only allow certain frequencies to the tweeter which will make a dramatic difference. Also do you still have the monsoon cd player? The stock speakers are 2 ohm and your alpines are 4 ohm which is only getting half the power your stock speakers were which is why it doesnt seem loud. get a small amp and hook them up to that.
Old Dec 26, 2004 | 01:10 AM
i wanted to leave that amp because i looked at the fourm thing and they said that would work. i dont have money for an amp. they said it would be better and raved about it it even has a stick at the top of the pag but its but what was expected at all? u thing the ohms r ****** up with only half the car done?
Old Dec 26, 2004 | 01:37 PM
shouldaboughttheZ's Avatar
No the ohms are going to mess it up with only half the car done. As stated earlier, you installed a 4ohm speaker, stock one is 2ohm. Stock 2ohm speaker is going to make the amp put out more power.
Old Dec 26, 2004 | 10:04 PM
WhiteBird00's Avatar
Ungrounded Moderator
Originally Posted by shouldaboughttheZ
...Stock 2ohm speaker is going to make the amp put out more power.
Not exactly... the 2-ohm speaker doesn't make the amp do anything - it's just louder at the same power level than a 4-ohm speaker. Theoretically, it would be twice as loud as a 4-ohm speaker at the same power level but that doesn't take into account other factors such as speaker efficiency.
Old Dec 26, 2004 | 11:43 PM
How do you get the same power rating on two different ohm speakers. I pulled out my orion amp book and looked it up. If you have a 4 ohm load on the amp you are only going to get 100 watts(on the amp in my book). At 2 ohm the amp will put out 200 watts. So how is it just louder at the same power level? Are you telling me that 200 watts is just as loud as 100 watts?
Old Dec 27, 2004 | 01:06 AM
well i did the other side today and i have to say im disappointed. its not as loud. b4 i never turned it up all the way today i did because it wasnt enough. clearer i guess to a point. but if i have it up and the equiler is up on the tweetwe part it gets nasty. this sucks i was hopping for better. nething i could have done wrong?
Old Dec 27, 2004 | 01:08 AM
also would the speaker sound better if i did end up puting a better amp for them in there. from the sound i get doesnt seem like they could handle it but i dont know.
Old Dec 27, 2004 | 09:10 AM
It's a question of semantics. What I meant is that at the same level on the volume control, a 2-ohm speaker will be louder than a 4-ohm speaker. The amp can never put out more power than it's rated for but (if it can even handle a 2-ohm load - some can't) the 2-ohm speaker will produce the rated power but a 4-ohm speaker will produce half the rated power output(approximately). This is exactly what your manual says - a 200 watt rated amp will put out 200 watts into 2-ohms but only produce half the rated output into 4 ohms.
The Monsoon amp is rated at a 2-ohm load so putting in 4-ohm speakers will reduce output. It doesn't actually reduce the power capability of the amp - it just means that more power is dissipated as heat trying to drive twice the load it was designed for, so the volume is lower. In other words, the speakers aren't changing what the amp is doing but the power isn't being used as effectively on the higher load.
It takes ten times as much power to produce twice the volume so doubling the impedence of the speakers doesn't cut the volume in half but it does reduce it somewhat. Also, the OEM speakers are not very efficient so installing high efficiency aftermarket speakers (even if they are 4-ohm) will keep the volume difference from being quite so big.
Old Dec 27, 2004 | 06:33 PM
GOTCHA! thanks.
Old Dec 27, 2004 | 11:06 PM
liquify33's Avatar
What I did was swap the fronts out (which you have already done) and run a 4 channel amp -- 2 channels to the front speakers and the other 2 bridged to a sub in the trunk. I intercepted the speaker wires from the monsoon amp to the fronts to run as little new wire as possible, leaving the sail and rear speakers hooked up to the factory radio. The reasoning behind using the factory speaker wires was that I didn't want to take the door panels off again, and the way the wires are spliced it will take less than 10 minutes to go back to stock.
With this setup (for under $300) the radio sounds WAY better and is plenty loud enough for t-top off cruising even with open headers.
Your Alpines should be able to handle 50 watts and yes they will sound tons better when not hooked up to the factory turd amp. There's no way to make that turd of an amp smell like roses, so bury it!
Old Dec 27, 2004 | 11:33 PM
what amp u guys suggest? should i have it push the mid bass subs or jus let them be. the mid bass subs will b the RF subs. what power level should i look for?
Old Dec 29, 2004 | 11:58 AM
wickedwarlock's Avatar
by a 4 channel amp. Every speaker with a channel from an amp. It will give you more control. The only exception is the speakers combos, I mean, speakers that come with a tweeter seperate. (seperates)
Old Dec 30, 2004 | 01:37 AM
i know a 4 chanel amp but should i push the fronts and midbass subs? and what watts
Old Dec 30, 2004 | 08:49 AM
how much power (rms) are you running to the subs? What brand again?
this will determine the amount for the fronts and mids.
a good range is 35 watts rms - 75 rms. It just depends on you power to the subs. I mean, if you are pusing 2500watts rms to the subs, than obvious, having 35watts to the mids, etc won't be loud enough. you could always go for 75 rms and turn down the gains, this will leave you open for upgrades in the future. I mean, if you wanted more bass down the road, you won't be left stuck with not enough power for the fronts and mids. Does this make sense to you?
Old Dec 30, 2004 | 02:14 PM
im talkin the mid bass subs. i have plans for subs (brahamas )but thats a while from now. i have the alpines up front and rf coming in soon. the ones that are on the sticky with upgrading the monsoon system.
Old Dec 30, 2004 | 05:20 PM
slow trap's Avatar
i didn't know the factory monsoon system was 2 ohms.do they make 2 ohm component sets now?
Old Dec 30, 2004 | 06:22 PM
Rogue Leader's Avatar
theres plenty of 2 ohm component sets... the monsoon amp does not put out enough clean power to drive them well...
Old Dec 30, 2004 | 11:54 PM
rogue what amp u suggest to push the speakers and mid bass speakers u recommended
Old Dec 31, 2004 | 11:07 AM
Theres so many options.... however you dont need a monster amp.
I used to be an Alpine installer and I am a big fan of their equipment. Their V-Power series is a good cheap amp. You can pick up a MRP-F240 to power them very nicely and you can add a pair of new speakers in the far back to run too. Or if you can find a decent lower power pair of 4 ohm subs (such as the Koda 6 mentioned in the sticky thread on top on the last page) you can pull your rear subs and run those off the other two channels on the amp.
