New speaker suggestions
Old Feb 16, 2005 | 05:48 PM
Firehawk526's Avatar
Originally Posted by DreamState23x
Ok, I found the weight, 36square feet is about 30 pounds. Maybe be a little more weight than I want, think I might just do both doors and the sail panel area. Still need to know about putting it behind the speakers though, sounds like a good idea to me.
As much power as I am running, I didn't want vibration, or door buzz so mounting them onto a firm surface only seemed the logical choice, 3/4" MDF provides nice backing for those 6.5's.
Old Feb 16, 2005 | 05:53 PM
Water will only enter from the outside (rubber molding/window), and I drove around 4 weeks this winter (window motor/regulator replacement) and only noticed a small amt of water that trickled down inside the door. Absolutely no problems, and I even checked out my 6.5's after being in the car for 1 year.
Again, they look brand new, no moisture buildup or deterioration that I could see anywhere. Actually, I was astonished. So, I can understand you concerns. You should not have any problems.
