Light's wont turn on.....strange.....!!?? Im really not sure if you guys will be able to help me, b/c the problem seems to be complicated but ill give it a shot. Recently changed all of my interior lights to led's, they all work fine.... But when i open my door they dont turn on, the only time when they do is when i turn my alarm off. I checked the fuse its still good, but could there be something else that i missed? Help appreicated! |
ttt :) |
ahh you guys are useless |
My only thought is that there is some type of actuator or switch that the led's are not compatible with, did you remove anything when installing them???. :confused: |
do u have a button next to where u turn your headlights on, if there is a button around there check to see if it is pushed in. on my 01 tahoe that button was pushed in when i first bought it and i had no clue about it, none of my interiors would go on. i finally saw that and pushed it and everything worked. |
Go back and check all of your solders. Make sure you didnt jump/short anything. It makes sence...it was working before...now its not. |
| All times are GMT -5. The time now is 08:18 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
