DIN trouble
Old Apr 10, 2005 | 11:30 AM
s537's Avatar
Default DIN trouble
I bought a DIN receiver and a 1/2 DIN equilizer. The Metra kit 1 & 1/2 DIN faceplate/mount isn't big enough for my particular 1 & 1/2 DIN setup. Help?
Old Apr 10, 2005 | 12:37 PM
99FormulaM6's Avatar
hmm what is your setup...? 1 1/2 usually works..
Old Apr 11, 2005 | 12:55 AM
s537's Avatar
Clarion stereo & eq. Stereo is 1 DIN and eq is 1/2. The metra kit isn't big enough. It seems that I need a 1 & 3/4 DIN kit or something odd like that.
Old Apr 11, 2005 | 12:58 AM
Daley's Avatar
I've run into this, although I can't remember what brands or components. Luckily I do remember the fix. Get yourself a flat file, and make the room you need. Be sure that the components will actually fit in the dash first though. My guess is that there's some sort of trim ring or bezel around one of the components that's taking up the extra space. Sometimes those bezels can easily be removed - check it out.
Old Apr 11, 2005 | 02:36 AM
ultraz's Avatar
AHAHHAHAHA,
ok ok, its that the radio in the kit is placed EXACTLY in the middle, thats why its not fitting........ u have to move up the radio a notch, so that its flush with the top of the trim, then make some kind of strap to have it underneath and u gotta use a file to cut the extra plastic UNDER the radio.
Old Apr 11, 2005 | 02:51 AM
Daley's Avatar
It's either that or get one of the kits that already have a provision for a 1/2 din eq. If you've already bought the one you have and can't return it (or would cost to ship) I'd break out the file and a six-pack. BTW, be sure and post pics when you're done!
FWIW, a dremel with a small drill-bit works extremely well in plastic, but be careful - it works extremely well!
Old Apr 11, 2005 | 04:19 AM
Darth Cypher's Avatar
Take some pics after you get this worked out. I would like to see how a 1 DIN and equalizer look installed. I hate how a 1 DIN looks in a 4th Gen dash.
Old Apr 11, 2005 | 09:54 PM
2FAST4U's Avatar
Sounds like you have the wrong dash kit!
there are many dash kits that fit your car.
ABS plastic dash kit is your friend If you have to get custom..
Old Apr 11, 2005 | 10:11 PM
Daley's Avatar
You must be referring to the kits that make the HU stick way out. Yeah, I never liked those either - too 'aftermarket' looking. When I was an installer, we had some kits that made 'em mount flush, but they were like twice the price of the standard ones (although much more worth it in my book). If I remember correctly, there might be some filing in the corners of the factory trim piece, but 2FAST could probably confirm this as I'm sure he's seen it more recently than I have. I've slept a few times since I last did one
Old Apr 12, 2005 | 11:14 PM
s537's Avatar
I will work on it. The kit has a spot for it but it just doesn't fit. It is a METRA and I think filing will be my only hope with it. If I ever succeed I will post a couple of pics.
