where to get ??
Old May 14, 2005 | 09:01 PM
B-RAD2's Avatar
Default where to get ??
i want the box that fits in th cubby so i still have room for my t-tops? where do i get it from???
Brad
Old May 14, 2005 | 11:51 PM
02Z28LS1's Avatar
both JL Audio and MTX make pre-made and pre-loaded subwoofer enclosures that fit in that area, but if you want just the empty enclosure, you can get those from Here or Here
if you want dual subwoofers and still want room for the T-Tops, check This Page out.
Old May 14, 2005 | 11:56 PM
02Z28LS1's Avatar
to make it really easy, if you haven't already purchased a subwoofer, i'd personally go with the pre-loaded JL Audio Camaro/Firebird Stealthbox, as they have done the homework and matched the sub to the enclosure perfectly, all you gotta do is connect your amp to it and rock. keep in mind, that this will probably be a bit expensive, but will be extremely easy to install, and is guaranteed to sound good, assuming you power it properly and set the crossover right.
Old May 15, 2005 | 08:33 AM
Lights_Out's Avatar
I got mine from Sub Thump check them out
Old May 15, 2005 | 10:50 AM
B-RAD2's Avatar
hey thanks guys
Old May 15, 2005 | 06:52 PM
2MuchRiceMakesMeSick's Avatar
https://ls1tech.com/forums/showpost....27&postcount=9
