I'v been wondering... Whats the difference between the monsoon 10 speaker system in the 97-02 firebirds and the regular 10 speaker system in the older 4th gen firebirds? |
BAM! :devil: Monsoon System: Indash CD-Player or Cassette Deck, 10-speakers (6-3/4" mid and separate tweeter located in each door, 6-3/4" dual voice coil subwoofer located on the sides where the rear passengers sit, 4" mids along with tweeters located wayy back in the hatch area.) and a factory Amp which is located next to where the spare tire is (the amp mounts on a plastic plate and tucks inside the rear fender area, you have to remove the spare tire to see it). Regular Stock System: Indash CD-Player or Cassette Deck and 4 speakers. (Two 6-3/4" speakers up front, one in each door... and two 6-3/4" speakers in back where the rear passengers sit) There's also anoter system called the "Entertainment System" which is exactly the same as the Monsoon (same layout, amp, speakers, etc.); however, it just doesn't say monsoon. Open your drivers door and look on the side of the door for the RPO codes (3-digit codes). See if you have any of these: UL0 AM/FM Cassette ETR 200 Watt Monsoon Sound System w/cassette UN0 AM/FM Cassette ETR 200 Watt Monsoon Sound System w/CD player UN6 Radio, AM/FM stereo, Seek/Scan, Auto Reverse Music Search Cassette, Clock, ETR UQ0 Speaker System 4, Dual Front Door Mounted, Standard Range Quarter/Shelf UU8 Radio, AM/FM Stereo, Seek/Scan, Auto Reverse Music Search Cassette, HPS, Clock, ETR U1A CD radio, 10 speaker U1C Radio, AM/FM Stereo, Seek/scan, Compact Disc, Clock, ETR U1S 12 Disc Compact Disc Changer U1T Radio, AM/FM Stereo, Seek/Scan, Compact Disc, HPS, Clock, ETR U18 Speedometer Instrument Kilometers U19 Speedometer Instrument, Kilometers and Miles, Kilometer Odometer U62 Speaker system 4, Dual Coax Front, Dual Coaxial Package shelf U65 Speaker system 5, Dual Front Door Mtd, Dual Ext. Range Panel, Single Rear Compartment U73 Antenna, Fixed U75 Antenna, Power UT6 AM/FM stereo, seek/scan, auto rev UW2 speaker system, 10, quad front door mounted, dual rear sail panel V73 vehicle statement, US/CANADA VG8 Label, Vehicle, Notice to Buyer VH5 Plate, Vehicle Information VK3 License Plate, Front Mount Package VM3 label information consumer, contains bumper impact standared VP6 Noise Control WS6 Performance Package - Formula/Trans Am WS9 model conversion, FORMULA WU8 SS Performance Package/Appearance Package - Camaro W51 Entertainment system - Radio, AM/FM-stereo, seek/scan, cassette, 4 Speaker system · Standard Range W52 Entertainment System - Radio, AM/FM stereo, Cassette, Equalizer, 4 Speaker system - Coaxial W53 Entertainment System - Radio, AM/FM Stereo, Compact Disc, Equalizer 4 Speaker System - Coaxial W54 Entertainment System - Radio, AM/FM Stereo, Cassette, Equalizer, 10 Speaker System, Amplifier W55 Entertainment System - Radio, AM/FM Stereo, Compact Disc, Equalizer 10 Speaker System, Amplifier W57 Entertainment system - Radio, AM/FM stereo, Cassette, Equalizer, 4 Speaker system - Coaxial W58 Entertainment system - Radio, AM/FM Stereo, Compact Disc, Equalizer, 4 Speaker system - Coaxial W59 Entertainment system - Radio, AM/FM Stereo, Cassette, Equalizer, 6 Speaker System, Dual Front Door Tweeters/Woofers, Extended Range Shelf W66 Merchandised Package - Formula W73 Entertainment system - Radio, AM/FM Stereo, Compact Disc, Equalizer, 6 Speaker system, Dual Front Door Tweeters/Woofers, Extended Range Shelf |
So if there exactly the same, how come did they start labeling it "monsoon sytem"? |
Originally Posted by Josh_101 So if there exactly the same, how come did they start labeling it "monsoon sytem"? |
Originally Posted by Josh_101 So if there exactly the same, how come did they start labeling it "monsoon sytem"? My guess is marketing :thumb: |
| All times are GMT -5. The time now is 08:45 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
