LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Wiring, Stereo & Electronics (https://ls1tech.com/forums/wiring-stereo-electronics-19/)
-   -   Quick stock cd player and system Q's. (https://ls1tech.com/forums/wiring-stereo-electronics/394235-quick-stock-cd-player-system-qs.html)
JerseyLS1TA Oct 13, 2005 12:16 AM
I want to buy the stealth box and a 10" sub with a small amp, but will it hook up to the stock monsoon cd player? Or will I need an aftermarket cd player?
LSfast1 Oct 14, 2005 04:35 PM
yes you can run a sub off of your factory monsoon system. but you have to run a HP because you do not rca cables from the factory. if i were you a would just buy a decent cd/mp3 player head unit for about $150-250 and use that. because it will be much easier to control the sound and get all of your levels correct with that than it would be with the factory head unit
WhiteBird00 Oct 15, 2005 07:55 PM
No, just install a line-level adapter like the PAC OEM-1 to provide the pre-amp RCA output for your amp (any amp you want) and everything will work fine.
© 2026 MH Sub I, LLC dba Internet Brands
