Turn signal problem
Old Nov 17, 2005 | 06:08 PM
Bill's 02 Z-28 SS's Avatar
Default Turn signal problem
Hi Folks
97 Z-28. I have a problem with Right turn signal - when the car is first started and running for a while, the right turn signal work Ok. Then sometime later it stops working - the back light comes on but not the front - replaced the bulb and looked at the wiring/connector - looks OK. Let the car sit for a while and touch nothing, restart the car and it starts working again. The left side OK - no problem. I think it is the DRL module - any thoughts? does anybody have a part numberfor the DRL.
thanks
Bill
Old Nov 18, 2005 | 02:58 PM
Hi Folks
somebody must of had this problem - anybody??
Bill
Old Dec 1, 2005 | 05:09 PM
half-n-half's Avatar
same problem...just changed the bulb...no help.
TTT
Old Dec 1, 2005 | 06:19 PM
komik's Avatar
I'm not entirely sure how / where the DRL and Turn signal systems connect, but you may want to just go ahead and replace the socket. It only costs $6~$7 at AutoZone. Considering how many of these fail (mine included) it's worth a shot.
Looks can be deceiving.
Old Jan 2, 2006 | 11:59 AM
slim_john's Avatar
i have a similar problem: Passenger DRL not on, turn signal not working. I changed out the socket, (mine was full of crud). connected it and it work for about 5 minutes then the DRL and turn signal stopped working. I have searched and I am wordering there the DRL module is located so i can change that out.
by the way if you go to Gm part direct they have the module for sale there but the part number is not listed.
