Courtesy lights. Help plz!
Old Dec 31, 2005 | 03:44 AM
kraaazymike's Avatar
Default Courtesy lights. Help plz!
K I searched for a while but it looks like im either A) a retard or B) threads were purged because I know Ive seen this here before.
My courtesy lights wont turn off at all. I disconnected my battery for precautionary reasons. I know I have to check out the pin switch in the door but how do I test it to see if its working properly? Wires to check with a voltmeter? Or just clean it out? Add electrical grease? Need the help guys! Thanks!
Old Dec 31, 2005 | 09:16 PM
2002_Z28_Six_Speed's Avatar
The wire bolts into the latch on the door. You could take the door panel off and then close the door. From the inside use a multi-meter to check the continuity of the switch? Maybe it is broken...? If so it wouldnt be a closed circuit when the door is closed.
Old Jan 2, 2006 | 10:42 AM
Well I took the door apart and fiddled with the switchh but got lazy and decided to just unplug the lights until I found more time to do it. As I was unplugging the lights they magically turned off by themselves and I havent had the problem ever since. Go fig! Thanks anyway 02 z28 6spd!
