cruise control not working
On your clutch pedel, there is a switch thats on the front side not behind it but in front of the arm. As you push the clutch in, this switch has a cylinder come out and that triggers cruise control to turn off. I bet is has backed out and you need to adjust it so the cylinder is in all the way when the clutch is not pressed.
The switch is plastic and white, check it out and post back here if that was the problem buddy.
Peace,
Craig.
mine works sometimes, but sometimes it doesnt. and if it is working....if i use the turnsignal it will stop working...
but this is something easy to look at, so ill do it tomorrow
Go ahead and check out that switch, if thats not it might want to start looking for a short somewhere.
Peace,
Craig.
Then adjust it by the nut that goes around it.
Peace,
Craig.
