stock alarm help
Old Mar 5, 2006 | 01:58 AM
TwoFast's Avatar
Default stock alarm help
Well I just got my 98 z28 friday and it has a factory alarm installed I believe. After I unlock the door with my key, I open the door, if I don't put the key in the ignition in 5 seconds, then the alarm goes off....is there any way to turn it off or get it to stop doing that. I have a key fob that I got with the car but it doesn't work, so I'm going to get a new one..is there anyway to get the alarm to turn off because I hate having to open the door, then immediately putt the key in the ignition to keep the alarm from going off. any info will help.. thanks
Old Mar 5, 2006 | 09:52 AM
WhiteBird00's Avatar
Ungrounded Moderator
Your alarm is working exactly the way it's supposed to. You can program your remote using the instructions posted here. If your remote is damaged and won't program then you can program the alarm off as described in your owner's manual. The instructions are posted here in case you didn't get a manual with your car.
