LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Wiring, Stereo & Electronics (https://ls1tech.com/forums/wiring-stereo-electronics-19/)
-   -   Dang LED's WTF????? (https://ls1tech.com/forums/wiring-stereo-electronics/474499-dang-leds-wtf.html)
ls1king000 Mar 22, 2006 05:55 PM
Dang LED's WTF?????
So, I done a lot of led's in my car but this one kills me. I started doing the front map lights and they worked out beautiful. I then moved on to the rear interior lights above the rear seat and it dosen't work !!!! Nothing
I brought the board that I made to my work and lights beautiful and went up to 11.5 Volts. Bright as hell. Today I go with the board to my car and connect it. Nothing. What the hell is goin on??? Broken wire somewhere??? :bang:
88monte Mar 22, 2006 06:48 PM
check to see if your accidentally grounding it on the metal body, i had a similar problem when my interior lights would go on by itself and go off by itself. one of the metal clips was grounding to the frame. i hope that helps
Luna Mar 22, 2006 06:49 PM
maybe they arent getting enough power , did you plan for about 14 volts? thats roughly what it is when the car is on
evilbadz Mar 22, 2006 07:01 PM
When I do all my LED projects I aim for 13.5. That is what you should design for, although LEDs are very forgiving on power requirements provided that you usually stay withing a .4v range (usually).
ls1king000 Mar 22, 2006 07:24 PM
100 ohm resistor for all led's and i gave it a shot of 14.5 volts with no led's burning out. I coated all ends with hot glue gun and just took another look at my car. everything looks ok??? I don't get it. I have no clip to ground out.
Thanks for helping though
If blew a fuse, wouldn't my maps not work too?
Luna Mar 22, 2006 07:31 PM
well check the voltage at the dome light with a multimeter, and make sure you have them hooked up in the right direction, remember polarity is pretty crucial with LEDs, ground to power power to ground instead of vice versa = no light
ls1king000 Mar 22, 2006 07:36 PM
Thanks luna, I ll have to grab one from work tomarrow. I'm stupid today LOL. Is it friday yet!!!!! I'll get to the bottom soon. Checking off possibilities
LawmanSS Mar 22, 2006 10:29 PM
Let's try this one here...you may get additional help.
1QUIKWS6 Mar 23, 2006 03:46 AM
Just a stupid question, but how long AFTER you opened the door did connect the light? Cause you know there is an auto-off function to the interior lights - after a period of time they will go out by themselves - hence no voltage at wire. Check with voltmeter to see that you are actually getting voltage back at the light and as mentioned earlier (or just close your doors & hatch after you install and then reopen one to reset the interior lighting cycle).
Also could be you blew a fuse for the interior lights - I don't think the map lights & interior lights are on the same circuit. Are the other interior lights on under the dash in the footwells when you are trying this?
I would guess that your polarity/resistors are correct as you stated that it works when you test it on the bench at work.
LawmanSS - I see you're a big time Mod now - how do you rate, & how much did you have to pay them to take ya in? :jest:
Good to see a local guy in a 'psuedo' position of authority! :)
Are you planning on attending the T/A Nats in Ohio this August? If so, we can hook up and drive over/park together...
-Jay-
leres Mar 23, 2006 12:11 PM
What value resistor are you using? Maybe you ran too much current thorugh the LED and burned it out? Anyway, once you get a meter, you can check a lot of things, including the LED.
lo_jack Mar 23, 2006 02:14 PM
How are you testing the dome light when you are installing it? I tried to install an LED bulb not long ago and before I realized I did not need to, unscrewed the whole housing from the roof. Well I think that thing grounds via the screws, so it totally didn't work until I screwed the housing back in. Or maybe I am nuts, but when I just stuck the bulb back in when it was screwed down, it worked.
Hoping it is something easy like that for you.
1QUIKWS6 Mar 24, 2006 03:34 AM
The rear light in at least the 2000+ cars do not rely on the mounting screws for the plastic housing to the car to ground the system. There is a (2) wire connector inside the housing to the bulb and that is it...
ls1king000 Mar 24, 2006 11:44 AM
Yep that's it. I haven't got a multi meter yet. I'm going to check it out this weekend.
Thanks everyone for input.
98z2006 Apr 21, 2006 06:33 PM
nrebie question anyone changed out hvac and cluster lights to led? I tried and not gettting power to yellow and grey wires now at hvac and light instument cluster no longer working any help nice!
© 2026 MH Sub I, LLC dba Internet Brands
