Panel Rattle
Old Mar 29, 2006 | 10:22 AM
SS4Luck's Avatar
Default Panel Rattle
I have an 02 SS with the Monsoon system, and ive noticed that recently when the bass hits, not even turned up very loud, just a good shot of bass, my panel in the rear passanger area rattles, and so does the one in my door, both are on the drivers side.... any ideas to fix this? it really annoys the hell outa me
Old Mar 29, 2006 | 11:25 AM
CashMoney's Avatar
Either tighten the panel down or add a cushion between the two.
Old Mar 29, 2006 | 12:57 PM
2001NBMZ28's Avatar
My drivers side door has always done it, stops if I reach down and put pressure on it. One of these days I'm going to take the door panel off and put weatherstripping between the door and the grill. The rear panel is easy to get to.
Old Mar 29, 2006 | 02:32 PM
todddchi's Avatar
99% of the rattles in our cars are due to a panel being improperly re-installed (very common on door panels) or because a plastic fastener has broken. Some of the larger panels also have what is basically plastic velcro. Often times the plastecro is stronger than the glue used to attach it to the panel and the body, so it comes off as an assembly when you pull the panel. The fuse panel is the first place I can think of, some of the dash and interior panels use it too.
I've found super glue works pretty well to tack these back to the appropriate sides so the velcro works like it should.
Once you take the time to examine the panel in question, the problem should be pretty obvious.
Squeaks are what you've really got to worry about. Rattles are easy.
