LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Wiring, Stereo & Electronics (https://ls1tech.com/forums/wiring-stereo-electronics-19/)
-   -   wiring idea's? (https://ls1tech.com/forums/wiring-stereo-electronics/495291-wiring-ideas.html)
weaponZ Apr 24, 2006 09:41 PM
wiring idea's?
im looking for some idea's on fixing all the power wire's under my dash for my guage's,shift light,nx.....
is there somthing like a distrubution block to tie everything togther?i dont feal like its too safe with all the power's tied into one wire.what if i run a thick wire from the battery and wire in a relay?maybe half my power wires on one wire?
does this make sense?
jimmy 2 Times Apr 25, 2006 08:27 AM
run a relay, simple fix
WhiteBird00 Apr 26, 2006 07:29 AM
This is a common problem for installation of additional lighting and other accessories on motorcycles. So there is a solution on the motorcycle aftermarket. It's a power distribution block with a large gauge battery input wire and a relay to switch the output terminals on and off with the ignition. It can handle up to 30 amps total on six accessory circuits. Check it out at The Electrical Connection. (Go with the universal model since the others are made to fit specific motorcycles.)
weaponZ Apr 26, 2006 08:43 PM
that's exactly what i had in mind,but for 44.00's i might be able to peice one togather cheaper.thanks
WhiteBird00 Apr 27, 2006 07:06 AM
Yes, you can buy a fuse block from an auto parts store for under $10. Then you can add your own heavy gauge feed wire and run it through a 30 amp standard relay to make it ignition-switched power. Those fuse panels are bulkier than the motorcycle setup but there should be plenty of room behind the dash to put it.
weaponZ May 20, 2006 09:16 AM
any other option's?im ready to order.
does summit offer any simulor kits?
i found this kit
http://store.summitracing.com/partde...5&autoview=sku
can i use it and just wire in a relay and power wire?
WhiteBird00 May 21, 2006 06:46 PM
That's not really what you're looking for. That kit is just a junction block without fuses. It would provide a central connection point but you'd still have to have separate inline fuses for each circuit you attach. A fuse block would give you a single power feed with fuses and connections for each accessory circuit.
weaponZ May 22, 2006 10:10 PM
so it would be best to have everything on a fuse?kinda like a distrubution block for amps?
WhiteBird00 May 23, 2006 06:57 AM
Well, yes. There are a couple of reasons you'll want separate fuses for each of your accessory circuits. First, if something goes wrong with one of them then it will blow the fuse for that circuit but your other accessories will continue to work (plus it will be easier to troubleshoot the problem knowing which circuit blew a fuse). Second, in order to run all the accessories off a single fuse you would have to use a larger fuse to handle the load. That larger fuse would not blow as quickly as individual smaller fuses would, leading to a potential hazard.
You could accomplish the same thing using the junction block and individual inline fuses for the accessories but then you don't have all the fuses in a single place for easy access.
99blancoSS May 23, 2006 08:20 AM
You have a few choices for a powerblock but should fuse each item seperately as stated above. Check out darvex.com for parts. Its car audio stuff but its power distribution and fuses and such.
99blancoSS May 30, 2006 06:43 PM
How does that work? IF you want it to be switched power how does the relay make it switched if its wired direct to the battery? I'm very interested in this as well as I have a few connections to makw :n2o pressure guage, line lock, which I was just going to attach to the n2o window switch power feed. But I like the idea of having a small block under switched power. Just not sure how the relay works.
WhiteBird00 May 30, 2006 08:18 PM
A relay is basically an electrically controlled switch. It usually has five terminals but you only use four of them. Two of them connect through a coil inside the relay. When power flows through those two it energizes the coil and closes the switch that connects the other two terminals. When the power is removed the coil releases and opens the switch.
So, you connect your power source (battery) to one of the switched terminals and the accessory to the other one. Then you connect an ignition-switched power source to one of the coil terminals and the other one to ground. There is always power on the battery side but it doesn't get to the accessory until the relay is energized. When you turn on the ignition, power flows through the relay coil to ground and energizes the coil to close the switch. Now power can flow from the battery through the relay to the accessory. Basically you've taken a high current constant (battery) power supply and made it ignition-controlled using a low current ignition source to control the relay.
99blancoSS May 31, 2006 12:28 PM
Which ignition control wire should I choose? Color of the wire and location would be nice as well ..lol I'm going to get the parts right now. Just finished installing the line lock controls and soldeing that alll together. Those little switches in that SJM kit work out real nice.
99blancoSS May 31, 2006 01:19 PM
Ok heres a question. Why not just use the ign slot in the fuse box to power the added fuse block ? That eliminates the need for a relay correct?
WhiteBird00 May 31, 2006 01:43 PM
Yes, except that it's difficult to run a large enough wire to handle a 30-amp circuit and still get the cover back on the fuse panel. If you add up all the fuse values for your various accessory circuits and can get away with a lower amperage feed then you could use smaller gauge wire from the fuse box. Don't forget to put an inline fuse in your supply wire because the IGN port on the fuse box is only protected by a fusible link (about 40 amps).
99blancoSS May 31, 2006 01:55 PM
Ahhhhh, the fuseable link. I was wondering if it was protected anywhere at all. I just need enough to run my nitrous gauge, n2o window switch and line lock. I'll add up the value of the fuses supplied in their install kits and post back. I dont want to fek stuff up, just make a nice clean install of everything instead of spaghetti. Other wise what wire shouild I tap for a relay if I go that route instead?
99blancoSS May 31, 2006 02:25 PM
Ok, found a couple things out. First the new n2o window switch runs off a 60amp relay.
Second the line lock has a 5 amp fuse.
Third the electric n2o gauge isnt fused and runs off a switched 12v power source.
Can I run all these things off the IGN?
I know the relay will draw its power from the battery feed but its needs a 12v switched connection as well right? (to turn it on?).
So my draw for all three of those should be pretty minimal but I'm not sure how much it is? How big of a wire will I need to run to the IGN on the fuse box?
OR should I do it differently?
WhiteBird00 May 31, 2006 04:18 PM
You can do it using an ignition-switched feed from the fuse panel. We know the line lock takes 5 amps or less. The coil side of the N2O window switch relay will draw one amp or less to energize the relay. The big question is the gauge but I expect that 5 amps would be more than enough. You could run a 16 gauge wire from the fuse panel with a 15 amp inline fuse and not have to worry about overloading the circuit.
99blancoSS May 31, 2006 04:56 PM
right on, thx for the help
© 2026 MH Sub I, LLC dba Internet Brands
