Got a wiring question.....
heater lead--->
opener lead--->toggle switch--> fuse---> battery
purge lead --->
I currently have to turn this switch on if I use the nitrous...I did it to force me to plan to use nitrous because I thought I had to set the MAFT richer to be safe. Well...that was ignorant idea because on a dry system you can adjust for the additional load by using LS1 Edit. I am describing this in some detail to hopefully help with my question...which is... What wire can I tap into coming out of the fuse boxes to give me power when the car is on? or, is there an empty fuse source I could use? My main concern is the heater power requirement..don't want to fry anything. Whew, hopefully this made since..it is late.
<small>[ February 23, 2003, 12:31 AM: Message edited by: BLUEBYU ]</small>
Thanks
heater lead--->|
opener lead--->|-->toggle switch-->fuse
purge lead --->|......................|<---|
|......fuse box-->|
|-------------->relay<----battery
ground----------->|
Sorry for extra lines but only way to show with this editor. Dots are spaces.
I observed their is a available 15 amp slot in the smaller fuse box. Is this ok? I guess that power is just to operate the relay...so should be fine?
Thanks for the insight!
Let me know if my diagram is right. Oh yeah, is there a certain type or size of relay I should get? Any recommendation here?
<small>[ February 23, 2003, 02:36 PM: Message edited by: BLUEBYU ]</small>
<small>[ February 24, 2003, 03:40 PM: Message edited by: BLUEBYU ]</small>
