Help me get this figured out.
Old Sep 1, 2006 | 08:43 PM
pHEnomIC's Avatar
Default Help me get this figured out.
Ok I have this amp:
http://www.crutchfield.com/S-hNZJBxD...asp?search=61x &i=158XMSD61X
Also have 2 JL Audio 12w3 dual-voice 6 ohms.
Well... I want to put some bump in my car but i can't decide how i should set this up. I have a 12 inch stealthbox built (have it apart atm for slight adjustments) and i know it isn't optimal for a 12 but it has sounded great w/ 2 seperate sub setups in a different fbody.
I was thinking about making a trunk box and using 2 12's but i still need trunk space and ttop storage ability.
What do you suggest I do?
Also with that amp, can i wire those subs up in parallel to get 1.5 ohms? Will i be fine running that or would that cause problems. I know for sure the amp is 2ohm stable but idk about 1.5.... Don't want to build the box only to find that it won't work.
Monsoon system btw.
Listen to mostly rock but a little bit of everything including rap and techno. My exhaust is loud enough to get me serious attention(lt,ory,bullet) but sometimes it'd be nice to be heard thumping from a block away as well.
Old Sep 3, 2006 | 12:52 AM
pHEnomIC's Avatar
TTT please
