Shiift Light ?
i turn key on and the light flashes set the rpm to 3000 to test it rev the motor and nothing. what did i do wrong i also set it for 4 cly
If its coming on & flashing back your setting then you have good power & ground, but had to have spliced into the incorrect tach input wire. There is no other reason for it not to work, unless it was messed up when purchased.
http://www.installuniversity.com/ins...sity/index.htm
