First system install.
Old Mar 10, 2007 | 10:28 AM
AaronR's Avatar
Default First system install.
Im going to attempt to install my first system this weekend.Car is a 98 Formula.I was just curious if you guys have any suggestions or things I should look out for that may not be covered in the FAQ's?Also should the computer actually be taken out of the car to get to the firewall hole?I assume it wont lose my tune or any info?Would really appreciate any help or suggestions.Thanks!!!
Old Mar 10, 2007 | 11:57 AM
KEE AUDIO's Avatar
More good info on systems for these cars is on Fbodyaudio.com. It covers just about anything you'd want to know about doing your first system and then some!! As far as your tune going away because you disconnect the PCM...not gonna happen. Check out that site as well as the FAQ's here and that should answer most of your questions. If not check back!! I'd be glad to try and help as well as quite a few others on here!! Good luck!!
Old Mar 10, 2007 | 01:39 PM
Blacker's Avatar
To determine what direction to go with a stereo install, you need to know:
1. How money you want to spend.
2. Do you want a stealth setup or go all out.
Old Mar 10, 2007 | 02:43 PM
fredmr39's Avatar
You still can go all out WITH a stealth setup, which brings you back to #1, if you are willing to spend the money.
But, it appears anyway that he's made his purchases since he said he will be attempting the install this weekend.
Any specs/info on the items to be installed?
Old Mar 10, 2007 | 03:04 PM
dragonrage's Avatar
Yeah, when my stealth setup is done, I'll challenge most of you with hatch boxes
Maybe I should take it to local competitions...
Old Mar 10, 2007 | 03:23 PM
Carlos01SS's Avatar
Pics of your stealth setup???
Old Mar 10, 2007 | 03:27 PM
dragonrage's Avatar
I can show you pics of the stuff on the floor of my room at the moment...
Old Mar 10, 2007 | 03:59 PM
Carlos01SS's Avatar
:spit:
Actually that'll work for me!!!
If you don't mind kind sir.
Old Mar 10, 2007 | 05:17 PM
AaronR's Avatar
thanks for the suggestions guys.Im in the middle of it right now.System consists of polks in the door ,pioneers in the sail panels,stealth box with a JBL 10 and a 4 channell MTX amp.My friend is helping me out,hes very knowledgeable thank god.Now were trying to mount the amp and looking for a suitable ground.
Old Mar 10, 2007 | 06:05 PM
dragonrage's Avatar
ok, pics https://ls1tech.com/forums/showthrea...70#post6621170
