How to splice in aftermarket speakers for backseat and rear hatch I haven't even looked at how it might be rigged, but I figured I'd ask first. They're some generic Wal-Mart brand, I believe. |
are you running any amps? are you talking about replacing the stock ones or adding more speakers. Dont get crappy walmart speakers, will be a waste of money, the monsoon speakers are better. Get some decent speakers if your going to put the money into it. |
Originally Posted by transambandit
(Post 8090873)
Well if you look in the sticky in this section there is one that tells which color wires come off the headunit to which speaker, but thats only if you want to run better wires. Otherwise just cut the wires off the old speakers and re-install the new ones. |
i wish i woulda known yall liked monsoon speakers so much, mine have been in the front yard collecting rain and dust for the last three months since i pulled them out and threw them on the ground. |
Originally Posted by 01ssreda4
(Post 8091659)
well they were as far as i know when i pulled them out. but as far as ebay goes, im trying to get rid of my monsoon amp and cd player and after 9 days not one single bid. this sucks. |
Originally Posted by Shackleford
(Post 8091497)
I'm all stock. I paid $30 for 4 speakers. Monsoon systems have subs in the sail panels and components in the hatch area (Firebird only - separate woofer and tweeter). The Monsoon amp filters the signal to the subs so you won't get anything but bass regardless of what speakers you install there. Installing cheap (coax?) speakers there will really sound bad. As for the hatch area, I doubt you got the correct 4" components for that price so what did you buy? |
Just spend the extra little money on the right set of door and sail panel speakers.....the best thing I could have done. I almost went your route because Im not huge on bass or big systems, I just like a good, full, clear sound when I listen to my music; I took some advice instead and spent a little money...the sound I got for the money spent is awesome. |
Ok, guys, we put the woofers in a little bit ago. They're 300-watt Pyramid Originals. It sounds all right. What size are the front two speakers? I need to replace the passenger front now. |
(Post 8095964)
(Post 8096096)
6-inch speaker, correct?
Originally Posted by Monsoon FAQ Firebird coupes have component 6.5S (6.5" oversize) 2-ohm mids and .75" 4-ohm tweeters mounted separately in the doors, dual voice coil 6.5S (4-ohm + 4-ohm) subs mounted in the sail panels (beside the rear seat), and component 4" 4-ohm mids and .75" 4-ohm tweeters mounted separately in the hatch area. |
Originally Posted by WhiteBird00
(Post 8096111)
Gee, I didn't see 6" speakers mentioned anywhere in the FAQ... |
© 2024 MH Sub I, LLC dba Internet Brands
