help installing door speakers!
Old Jun 14, 2008 | 02:03 PM
Irocem99's Avatar
Default help installing door speakers!
I have the door panels off,but the tweeters are on with some sort of tabs.. and I have spacers for the woofers and those are throwing me for a loop also..grrr I know a lot of you have done it.. Oh Whitebird,where are you?
Old Jun 14, 2008 | 02:14 PM
Dimitri-'s Avatar
You take the 'tabs' off.. + install the new tweeters using the same bracket to hold it
Old Jun 14, 2008 | 02:34 PM
Irocem99's Avatar
yes,but how do they come off? and the new speakers don't line up with the holes on the factory bracket and neither do the adaptors..arg
Old Jun 14, 2008 | 03:37 PM
Intercooler2's Avatar
You have options! Put the tweeters where you need them in the openings (centered). Go around the outside with a heavy bead of good glue/silicone (I use GE Silicone 2 in clear) if you think you may need to remove them later or something. For more permanent use a hot-glue gun around them. They don't move much if any at all since they are just highs so glue/silicone worked fine for me and I can peel them out and remove the silicone if ever needed. Allow them to fully cure in place before moving the panel.
Old Jun 14, 2008 | 03:56 PM
Irocem99's Avatar
LOL..intercooler,your reading my mind,I was just going to ask that question..It really is a pain in the *** to do!
