HID's So i put my new HID kit on that i bought from LEDvault, the fogs work just fine, and look good, the headlights dont work though, what should i check? I check the connections and made sure they were all in and tight. |
That you hooked them up right.. LOL.. Sorry, just check and make sure you have the right color wire to right color wire. Also that they're soldered good and correctly clicked in the connector.. Other than that, did they work before you installed the HIDs? Maybe you got a bad batch of em if all else pans out.. |
Try flipping over the connection that plugs into the balast. Thats how mine from Fashtek where. |
Ya, they worked fine before i plugged these in, and now they just dead, connections are all good, fit right, i was told to flip the male end 180, its like a bad connections or something. |
I just went and played with all the wires and connections again, and nothing. |
| All times are GMT -5. The time now is 02:13 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
