11 Second Club Snake eyes are a good thing
Can i expect 11's??
Old 09-06-2009, 02:15 PM
stangbeaterz28's Avatar
Default Can i expect 11's??
I just finished my 98 camaro rebuild. I have not taken it to the track in its present set up yet and i am wondering what i should expect?
98 Camaro Z28
Motor
-Ms3 cam 113 lsa
-ported ls6 intake w/ a completly ported and epoxied Z06 TB
-SLP ram-air/ LID/ K&N filter
-Ls2 timing
-TR 7.4 PR
-.660 springs
-Manley vlaves/guides
-853 heads
-ported ls6 oil pump
-Hooker Super Comps LT's
-Custom 3" x-pipe with true dual chambered dumps
-NGK tr-55 plugs
-MSD wires
Suspension/Wheels/Tires
-Sphon SFC
-LCA brackets/Bars
-stiffened up PHB (welded in some 3/8 square tubing)
-stock rear with 4.10's
- 11" wide rear Zr1 with HTRZ 315 tires
Other mods
-!AIR
-!EGR
-!rear 02
-cowl hood
-HURST shifter
Can i expect to be in the elevens with a hell of a burnout and some good driving??????????
Old 09-09-2009, 03:15 AM
Nitroused383's Avatar
Not without some drag tires. I doubt you will be able to cut much better than a 2.0 60'.
If you are around sea level I would guess 12.5 @ 117 mph with a 2.0 60'.
Old 09-09-2009, 10:44 PM
Juicy J's Avatar
Definitely need DR's. Those HTRZ's are not worth ****. I would recommend getting DR's and just rolling out... not launching.
If you go to the track, don't be upset if you are in the mid 12's. If you can get a decent trap, then at least you know 11's are attainable with a rear and some tires.
Old 09-09-2009, 10:50 PM
nitr0racing21's Avatar
with tire and driver mod I would guess 11.83 withouut tires 12.45
Old 10-08-2009, 08:04 PM
LSXFORMULA99's Avatar
get some et street and drive the **** out of it lol
Old 10-08-2009, 08:16 PM
Carter01's Avatar
I agree
Quick Reply: Can i expect 11's??
