11's to 10's question
My H/C car on a 150 shot in second gear has gotten me a best of 11.1 at 124 mph consistently with a 1.6 60 ft time. This on a stock suspension on a lowered car without lca's. My friend's car that ran me hit a 10.9 at 124 mph but he sprayed off the line cuz he has some suspension into it and a 12 bolt. I now purchased the adj. lca's, drag sway bar, adj. panhard bar, adj. torque arm and a brand new 3600 Vigilante stall multi disk (compared to the previous Fuddle 3600 single disk). My question is, with these new items intalled and a 12 bolt or 9" installed, which I'm looking to buy asap, would I be able to jump into the 10's easily? What you think guys?
With all variables being the same such as weather and traction I honestly feel 10s would be very attainable. The only thing that concerns me is you did cut a decent 60ft so you are probably only leaving a tenth or so on the table in the 60. With a 1.50 60ft you should hit 10.9 no problem.
You should most defenetly be there. my h/c full susp. car went 11.40 with a 1.53 60 ft. on tha motor. and 10.42 on 150 shot. so you should 4-show get where you are trying to get.
