Stock Internal DD Z28
Heres mine, just something to compare too, I have no idea what my car weighs.
Ac
Swaybar/brackets
Washer fluid tank
Front bumper support
AIR pump/tube/bracket
Plastic panels under the front bumper cover
Rear Seatbelts
Spare tire/jack
Rear speakers
T-top holder
15" wheels front and back
No catback
heat shielding
As far as the front bumper support, make your own brackets to keep it sturdy. Once you are under there you will see what to do.
Ac
Swaybar/brackets
Washer fluid tank
Rear Seatbelts
Spare tire/jack
Rear speakers
T-top holder
No catback
heat shielding
The intervals are also called the breaks, so 60, 330, 660, 1000, 1320. My suspension is nothing special. I have 3 QA1's since the guy I bought them from ripped me off and sent me one with a seized adjuster. My driver rear shock is a stock DeCarbon. I have Pavlock Performance aluminum LCA's in the stock mounting location, stock panhard bar, stock torque arm, Metco Driveshaft loop/chassis brace. Still have a stock k-member, a-arms, 10 bolt, etc etc etc.
Ac
Swaybar/brackets
Washer fluid tank
Rear Seatbelts
Spare tire/jack
Rear speakers
T-top holder
No catback
heat shielding
Ac
Swaybar/brackets
Washer fluid tank
Rear Seatbelts
Spare tire/jack
Rear speakers
T-top holder
No catback
heat shielding
I ran 12.1 last year @ 3400lbs.
Im hoping to see some 11's after a winter of weight reduction and some other mods. Hoping im 3300ish.
Still dont have tires or traction. Going to see how far I can take the stock internals
#32
I just put on the wsq hood so I am going to make a custom intake for that.
I ran 12.1 over a year ago. When the air gets better this fall hopefully a year of mods will put me deeper in the 11's
#35
That was my goal also to get on the top 50 for a SI car.. Someone need to update the list for people now where we need to be to get on the list. I have a SS4000/373s/LCA's/DR's/Frost tune I'am doing the 373s to get rid of the shitty 273s..
#39
cool cool I'm hoping for a 11s time slip this year. I'm hoping I can get on the top 50. I'm doing weight reduction.. I still have SS4000 stall and 373 gear to add and get it tuned.
