11 Second Club Snake eyes are a good thing
SGM WS6 Formula 11.4 mostly stock with video.
Old 01-24-2013, 12:15 PM
GoBabyvroommm's Avatar
Default SGM WS6 Formula 11.4 mostly stock with video.
Hey guys figure I share my run and mods.
Mods:
1 7/8 Pacesetter Long tubes
Off road y pipe into a Borla race muffler dump
Stock 342 gear
Built manual valve body trans
3500/3800 TCI converter
Control arms
NX Nitrous wet 150 shot
Speed Inc nitrous tune.
M/T 17" DR 275/40
Car weight with me not in it is 3320 with a little over 3/4 gas.
The nitrous kit wasn't kicking on right away which later I found out it was bad wiring on me and my bodies part. We didn't check things twice. I also install a shift light but didn't set the points the right way, this was leading me to shift early. Me shifting early end me up in 4th gear before I passed the 1/4 mile and I braked as well. That is why is why the mph was 115. I figure if I had a good pass the best I'd do is a 11.1 at 119.
O well now I have a different set up with a LS1 intake and cam! Lets see what it does next year. I hope this helps a lil with the set up some of you guys are looking to run.
Old 01-24-2013, 03:02 PM
work in progress's Avatar
Didn't know Pacesetter made a 1 7/8" header. What was your 60', 11.1@119 is a great time for such low MPH. Good runs either way!
Old 01-24-2013, 06:35 PM
Launchs were at 2300/2600 rpm. If i went higher i would blow the tires up.
18psi to 22psi depending the ground and air temp.
On motor on a motor tune no nitrous 1.65 60fts at 109mph. 12.3 1/4
On motor with nitrous tune no nitrous 1.66 60 fts at 105mph 12.5 1/4
On motor with nitrous spraying out hole 1.64 60fts at 115mph at 11.44
I should be doing 1.4's 60fts with the nitrous but its not hitting right away like you can see in the video or it might be going threw the convertor.
As for the headers, that is what I was told came with. Now I'm wondering if either they are pacesetters or something different. Hell i just might be wrong.
BTW I didn't run the 11.1 not trying to take my hat off here. I figure if things went a lil better that would have been the best. I hope my 60ft info helps out a lil.
Old 01-24-2013, 07:17 PM
ramairetransam's Avatar
how about more pics of your rare formula . i love ws6 formulas.
Old 01-24-2013, 08:18 PM
Sigh..... I would but my storage card broke so I have to wait till spring.
Old 02-01-2013, 09:23 AM
Jarred Hodges's Avatar
what was the 1/8 mile et and mph
Quick Reply: SGM WS6 Formula 11.4 mostly stock with video.
