11's out of my Protouring 69 Camaro
ok... i have been to the track two more times
first track day
11.65 @121 average with 1.85 60'
11.35@129 one spray pass with a 1.9 60'
Second track day
11.52@123.34 1.8 60'
11.55@123.12 1.8 60'
11.56@123.00 1.8 60'
11.31@129 1.9 60'
on spray (only one pass)
difference between day one and two.
day 1
et streets drag radials
steel rally wheels
day 2
hoosiers drag radial ( 10 lbs lighter each )
weld drag lites up front (skinnies)
passenger seat out
i really think i am not launching the car hard enough.. my crew is telling me im not really spinning that much... i think i'm about at 3500 when im letting the clutch out..
26" tires
373 gears
first track day
Second track day
11.31@129 1.9 60'
day 1
steel rally wheels
day 2
passenger seat out
26" tires
373 gears
Congrats on the pass.
What is the motor setup and how much power?
You definitely need to launch harder if you're not spinning. Get that 60' down to a 1.6/1.7 and you'll see the results you want. I know the car is not ideally setup for drag racing so, but try and squeeze every bit out of the launch you can! The more seat time you get, te faster you'll go.
Good luck!
Btw, you should post a pic of the car
Good luck!
