11.62 @ 116 was all I could get
I wish i could say my trans is slipping but my car is what it is, going on here im slow but in the last 5 years at my local track i have the fastest cam only and now heads/cam car ive seen, the ones with similar dyno numbers at the same shop but less weight loss and gearing do about 2-3mph less than me
This thread got me thinking and I put on paper everything I want to do over the winter. I started a new thread in the drag racing section if you are interested in following.
Thanks All!
https://ls1tech.com/forums/drag-raci...-3-tenths.html
Thanks All!
I ran the car over the hill to FJ Performance and put it on their Dynojet dyno. The first time on this dyno. It made 376 hp and 365 ft-lbs.
The trans looked good, no slipping. This pull was with the converter locked. I did find out the injectors were at a 98% duty cycle. I'll post the curve on my other thread.
That could be the issue. Not really slipping but just turning your power to heat. There has been a ton of guys pick up time just off the trans rebuild with no real issues showing before the rebuild.
#32
Typical DA is 3000-4000 and i run 11.9-12.0s@114-115ish then, best time in my sig was 1900DA, its a slow track haha, pullied cobras on the 480-500whp range are right on par with me too, even a heads/cam ls7 z06 only trapped 121 last time i was there when i was doing 115 that night
#34
Thanks for the feedback.
