11 Second Club Snake eyes are a good thing
Can I Make It?
Old 07-29-2005, 11:19 AM
Sold The Fun Stuff :(
josh99ta's Avatar
Default Can I Make It?
335rwhp/373rwtq unlocked through a TCI 4000 stall and 3.42 gears
MTI T1 cam, longtubes and true duals, stock springs, SFCs, reloc. brackets
Weight reduction list includes:
Suncoast fiberglass hood, !windshield wiper resevoir and fluid, !EGR, !AIR, !backseats and seatbelts, !spare and jack
17x9 w/ 275 up front, but the rear will have 16x8 salad shooters with 26x11.5 ET Streets so I should be able to hook it. I will also be taking out my front swaybar endlinks for more weight transfer. I weight 180 so that has to be added into the raceweight, probably balance out to around 3600 lbs I'd say.
Can I see an 11 second pass like this? If not, what will it take? Great DA? More power? Obviously the car could lose a few pounds. Just looking for suggestions. I'd like to bypass the 12 second club all together and go straight to 11s.
Old 07-29-2005, 06:53 PM
jessedale98's Avatar
Honestly, i'd have to say yes, N/A i went a best of 12.3 with a 1.64 60ft with 373's , but without the cam or longtubes, so im assuming yes at around 110mph. Let me know how you do.
Old 07-29-2005, 07:12 PM
Retired Street Racer
Matt D's Avatar
you should, if the weather isn't too hot. i run 11.49 on stock internals, so with a cam, you definitely should.
Old 07-30-2005, 08:49 PM
black02-z28's Avatar
I don't see why not, as long as you can hook it. Heat up the ET Streets and you'll be fine.
Old 08-01-2005, 06:25 AM
NXZ28's Avatar
You should be there with those mods. My setup is close to yours without the weight reductions. If you get close, just adjust your rpms you launch at. I had to go from 1800rpm down to 1400rpm and then ran the number. Good luck.
Old 08-01-2005, 11:31 AM
Scotty-Z's Avatar
Go for it Josh. I think you can hit high 11s with that setup.
Quick Reply: Can I Make It?
