Title Change
Title Change
My car at the track. I Just bought the car. Date is wroooong. that cobra got DESTROYED!
http://myspacetv.com/index.cfm?fusea...videoid=457512
Hey man, i have ARE stage 2 heads (2.08int and 1.60ext.), Lunati cam (226/226 with a .560 lift), Hooker long tube headers with custom Y-pipe and RT cats, Custom PCM tuning, BMR weld in sub frame connectors, Vigilante 3800 stall converter, Ported LS6 intake, 160 T-stat, ARE high volume oil pump, NGK plugs, SLP 85mm MAF, Spohn lower control arms, B&M tranny cooler, and power Slot slotted rotors with hawk brake pads. This run was on nitto nt555r extreme dr's. On the dyno it put down 374.81rwhp and 356.97Ft-Lbs of torque.
