Rocker Arm Round-up
Crane Gold Race 1.8's here with AFR heads. I had to remove the baffles from the driver side valve cover, but still using stock vc gaskets. Very happy that I've switched to adjustables!
Moderator
FYI, both Harlan Sharp adjustable and non adjustable fit under the stock valve covers. However, on 97-98 heads you may need to clear the outer 4 (2 on each head). They get very tight.
Also on my AFR 225's the HS's need a little clearence. Not sure exactly how much as I am waiting on my cam to order push rods. Once I have all my parts I can accuratley check it.
I can't remember cost on them. Maybe Nasty Nate will pop in.
