Advanced Engineering Tech For the more hardcore LS1TECH residents
How many CFM of air per RWHP, roughly?
Old 06-08-2010, 08:49 PM
joecar's Avatar
Originally Posted by DanO
I half agree with a few of you..
You can estimate what your power will be with mathematics.. many programs assist with this but require vast knowledge of fluid dynamics, chemistry, and engines
Companys typically START their engine designs by doing computer simulation then they build the engine test, "calibrate" the computer simulation model, and then make further iterations in the computer simulation to figure out what to try next, etc..
Computer simulation will continue to become more and more important, however, at this point, real world testing is still required for 'very' accurate results.
I do not agree that a volumetric flow rate of air can equal a brake horsepower value.
BHP = Fuel flow x BSFC
BHP = "MASS" air flow x AFR x BSFC
BMEP = IMEP - FMEP
all above are valid equations
BHP = "volume" airflow * multiplier <<--- NOT VALID!!
You'd be better off estimating a BSFC
Air volume flowrate and air mass flowrate are related by the density of air.
Old 06-08-2010, 08:56 PM
FASTFATBOY's Avatar
Originally Posted by Arfdog
I'd say the major factor here is the trans. The auto trans + converter is sucking all that power away. Everything else has similar efficiency, probably within 5% of each other. Gears, rear end, and tires all are for the same vehicle, so have similar construction.
Youd be wrong.
Old 06-09-2010, 08:26 AM
ryarbrough's Avatar
Originally Posted by FASTFATBOY
Youd be wrong.
Agreed. Hold a 7.5 locker in one hand and a 9'' locker in the other. Tell me it doesn't take more power to turn that. Same with the tires. Roll a 245/50/16 on a stock snowflake and a 325/50/15 on a prostar with the same initial force and see which one rolls further before stopping.
Old 06-09-2010, 06:09 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
Originally Posted by dmc454
A simple formula that I was givin was (CFM x .25) x 8= HP potential
Max CFM flow X .25 x 8 ( 330 x .25) X 8 = 660 hp (why not just multiply by 2? its easier than your formula) I understand you are trying to make it work for 8 cyls though.
This is the potential that your heads can make if all other parts are world class parts.
660 x .18= 541 rwhp You are wrong. Did you double check your math? Maybe you meant (660 - (660*.18)) = 541 or in easier form 100% - 18% = 82% then 660*.82 = 541
HP x .18(aprox HP lost from driveline )= rwhp
This was givin to me by 2 Pro engine builders with 45yrs of turning torque wrench. Hope this helps you
I hope said engine builders put less time into turning wrenches than they did into these equations, or they would take those combined years building 2 engines.
Old 06-09-2010, 11:41 PM
Arfdog's Avatar
Your hands and arms can generate about 1/6 HP. Not a good gauge of how much power it takes to turn a drivetrain.
The power it takes to turn a rear end is something like 10-15 hp at maximum speed. That's a fraction of the power needed to run an auto trans. Same with wheels and tires, driveshafts. Those together amount to another 5-10 hp.
The biggest power draw is the transmission, and a big auto/torque converter combination that can handle big power can draw upwards of 70 hp @ max speed (i've seen the power reading from a drivetrain dyno). That's your main power loss right there.
Old 06-10-2010, 09:53 AM
Stang's Bane's Avatar
This is the potential that your heads can make if all other parts are world class parts.660 x .18= 541 rwhp
The most important part. POTENTIAL. You really have to nail everything else to reach that. I have seen some stuff exceed it, but they are only for the very top of the line stuff. Max effort, no limitations race motors
Old 10-30-2012, 08:06 AM
ez2cdave's Avatar
Yes, I know it is over two years old - LOL !
Peak_HP = Flow_CFM x .257 x Number_of_Cylinders
This is estimated potential Peak HP to expect.
You multiply .87 percent times cam's theoretical max lift , round off to nearest .050" in Flow Test, then see what CFM is at 28 inches
example : .700" Lift cam
.700 Lift times .87 percent = .609" Lift
Flow head at .600" Lift , then take CFM at 28 inches and calculate HP potential with above formula
.257 Factor = for beginning engine builders and engines near 10.0:1 Comp Ratio
.285 Factor = would be for Professional engine builders with wet sump pans, lightweight rotating assemblies, low tension great sealing rings, deep oil pans, etc.
Excellent use of inertia/wave tuning with 9.5 to 11.5:1 Comp Ratios or
11.5 to 13.0:1 CR ranges without fully utilizing inertia/wave tuning effects.
.300 to .310 Factor = Current ProStock Technology with dry sump, unlimited carburetion, Hi Comp Ratio, ultra lightweight rotating assembly, etc, max use of inertia/wave tuning, etc, 14:1 to 17:1 Comp Ratios (usually no better than .3200 efficiency or no worse than .2980 eff %)
Old 10-30-2012, 10:08 AM
FASTFATBOY's Avatar
This may work at the crank, at the wheel there is no formula to pin down all the variables.
Old 11-23-2012, 07:03 PM
Reher Morrison's Avatar
You cant even calculate FYWHEEL HORSEPOWER like you are trying to do... Too many variables like
VE
BMEP
BSFC
You cant calculate REAR WHEEL HORSEPOWER per CFM with a formula.
If you wanna waste your time trying to do it...knock yourself out. You can build two IDENTICAL combinations and they make different RWHP AND Flywheel HP . WHY? Too many variables.
RWHP Variables are
Flywheel/clutch weight
Driveshaft weight
Rear end rotational weight
Wheel and tire combination
Gear ratio
COnverter effeciency, 2 indentical converters will have different effeciency numbers
Type of trans, turbo 400/350, 4L60E/4L80E all have different effeciency.
FLYWHEEL HORSEPOWER is easier to compute with a formula, but still has many many variables.
If you wanna **** up a rope...be my guest.
Finally, common sense prevails in this post. You CAN NOT get crank shaft Hp from CFM alone unless your talking an all out race engine making well over 2hp/cid (over 110% VE). WAY to many variables to quantify under that. Friction power alone can throw +-30 hp into the mix. Trying to arrive at some defined HP rating based on CFM is a fools errand without a computer based software modeling program. Trying to get RWHP on a chassis dyno is pure insanity!
Old 11-24-2012, 06:29 PM
Thunderkyss's Avatar
I guarantee Edlebrock, Crane Cams, & every other aftermarket manufacturer out there uses math to design a head, intake, cam, exhaust, etc...
As been stated earlier in this thread, pro engine builders will use math to determine what their goal should be. When their engine dynos a particular number they know right away if there is something wrong & if it's worth tearing it back down to find out what the issue is.
Old 11-30-2012, 05:49 AM
KCS
Moderator
KCS's Avatar
I don't think there's anyone out there breaking records with out of the box heads. Using the math is only good for getting a very rough estimate or just a starting point to improve upon. After that is A-B-A testing, and recording the results.
Old 11-18-2013, 09:26 PM
  #32
Patrick McNamara's Avatar
Apologize in advance for bumping such an old thread, but I came here via google, found some good info and I'd like to ask a follow up question.
I'm trying to reverse engineer an intake limiter, so that different engines which are different sizes get the same amount of air so they'll make approximately the same power.
I see the formulas which calculate what the theoretical max hp are, now what I'm trying to do is determine how to limit the air so the engine is only capable of hitting my set point.
Old 10-27-2020, 07:12 PM
  #33
Thomas Henao's Avatar
How did this work out for you?
Old 07-21-2022, 02:41 AM
  #34
Dian's Avatar
old but very interessting thread.
why does nobody measure brake specific air consumtion? this would give an indication of an engines efficiency, as opposed to bsfc that is mixture dependent.
Old 07-21-2022, 09:32 AM
  #35
Received 3,025 Likes on 2,356 Posts
Because air is free, and fuel has a cost. Which would you keep track of?
Old 07-21-2022, 09:43 AM
  #36
Dian's Avatar
havent we had this discussion somwhere else a few years back?
cost doesnt matter if you are after max power, no? you could compare different engines/set ups as to what they make out of the air mass digested. after all an engine is air limited and not fuel limited.
Old 07-21-2022, 09:58 AM
  #37
Originally Posted by Dian
Haven't we had this discussion somwhere else a few years back?
Cost doesn't matter if you are after max power, no? You could compare different engines/set ups as to what they make out of the air mass digested. After all an engine is air limited and not fuel limited.
The air depends on its density, which can change due to temperasture and altitude, There is little to no control over this. Too many variables.
Fuel parameters, however are far more controllable, due to its liquid state. If you control one of the two, the other's parameters will be close to what is needed.
Old 07-21-2022, 01:11 PM
  #38
Dian's Avatar
airmass doesnt depend on density.
here a real world calculation (ls engine, blown, max tq, max hp):
5000 rpm, 535 bhp, 344.6 lbs/h, 11.5 afr → 5.74 lbs/min, 2'605 g/min, 29'959 g/min, 23'045 l/min*, 813 cfm, 1.51 cfm/bhp
6600 rpm, 609 bhp, 442.0 lbs/h, 11.4 afr → 7.37 lbs/min, 3'341 g/min, 38'092 g/min, 29'298 l/min*, 1034 cfm, 1.70 cfm/bhp
* convert at you favourite temp, pressure and humidity. as correction factors used on dyno are unknown, very approximate but comparable back to back. (somebody check calc please.)
im surprised there is such a large variation. what does that tell you?
Old 07-21-2022, 03:12 PM
  #39
Looks like your example engine is far more efficient at 5000rpm than at 6600rpm.
Old 07-21-2022, 10:52 PM
  #40
Dian's Avatar
yes, but not in the conventionl sence of cylinder filling. unfortunately its boosted and corresponding pressure ratios are not given, so we dont know what volumetric efficiency is. however we see that the engine not only fills the cylinder less at hp peak, but also is able to make less out of the air ingested. the difference of 13% certainly reflects friction losses. maybe other factors? do thermodynamics deteriorate with rpm?
edit:
3100 rpm, 228 lbs/h x 0.205 x 11.5/229 bhp = 2.35 cfm/bhp
4000 rpm, 321 x 0.205 x 11.2 = 1.90
4500 rpm, 398 x 0.205 x 11.4 = 2.00
5000 rpm, 365 x 0.205 x 11.5 = 1.60
6800 rpm, 448 X 0.205 x 11.3 = 1.73
apparently this is not so much friction related. as the engine comes on the cam it improves dramatically. (same engine as above set up a bit differently.) looking at the jump 4500→5000 rpm im wondering if the data is correct. ok, from another run i get 1.55 for 4500 rpm.
i have no idea how dependable this data is. would be great if somebody could do this with his own data. published fuel flow is pretty rare, unfortunately.
Quick Reply: How many CFM of air per RWHP, roughly?
