Advanced Engineering Tech For the more hardcore LS1TECH residents
From Old To New Will It Work?
Old 10-14-2008, 09:33 AM
94Project's Avatar
Default From Old To New Will It Work?
i have a 94 trans am lt1 350
my friend owns a 2000 Firebird V6
he is buying my engine from me and wants to put it in his car.
will the k member off of the 94 trans am fit it anyway on the 2000 firebird?
some things need to be altered i presume, if not where can i get one to work with this swap?
Old 10-14-2008, 09:35 AM
z28mccrory's Avatar
The k-member will bolt right up. I would recomend going ahead and getting an aftermarket one, but both are interchangable. Only difference is the motor mounts.
Old 10-14-2008, 10:51 AM
94Project's Avatar
yeah eventually we will do that but we are lookin to jus put in right now an upgrade that later. so because the mounts on my k member already have the engine mounted to it i can just drop k member with engine an bolt it straight to the 2000 firebird?
Old 10-14-2008, 11:21 AM
z28mccrory's Avatar
Yeah
The 6 bolts that hold the k-member to the car are the exact same location on both.
I used to work for a place that made aftermarket k-members. The 93-97 and 98-02 both used the same jig to build, you just put a different motor mount jig on them.
Old 10-14-2008, 12:10 PM
94Project's Avatar
awesome thank you for the info that definetly settles the decision on doin it
Old 10-14-2008, 12:16 PM
z28mccrory's Avatar
Glad i could help
