Sponsored by: DashLynx
Fine scratches in clearcoat
Old 02-21-2009, 08:40 PM
metalmechanic's Avatar
Default Fine scratches in clearcoat
On Hood, Fiberglass,,,ive used reg, wax with an orbital buffer but you can see them when the wax isnt fresh, what will be a good way or pruduct, cleaner wax??
Old 02-21-2009, 09:44 PM
EchoMirage's Avatar
you need a swirl remover and porter cable. not a buffer. only a real PC will spin fast enough, with the right pad (white), with a quality swirl remover. tropicare swirl remover is what i use. 3M finesse-it is also very good.
Old 02-22-2009, 12:47 PM
ZaneO's Avatar
A cleaner wax is very unlikely to remove any swirls. You need a quality abrasive polish / swirl remover. And yes, you're also going to be very limited with a parts-store type buffer if that's what you're using.
Quick Reply: Fine scratches in clearcoat
