VHT help
It's really pretty straight-forward. Use some sandpaper on them to get them scuffed up a little, so that the VHT will stick. I used 1000 grit. Then, put as many coats of it on as you want. Then, a couple coats of clearcoat. If you want them to be shiny, I believe you need to wetsand between each coat, and then buff it after you're done.
