LED gauge cluster question???
You don't.
If you have a Trans am you just pop out the bezel that covers the guages and the light switch (make sure before you pull it all the way out to disconect the fog light wire harness). Then you will unscrew 4 screws around the gauge housing and pull it out. You will have to turn and lift the gauge housing to get it out so take your time. Then you can turn and twist out the old bulbs. LEDvault.com has a write up with pics on how to install.
